Hey all,
I've been having a rather bizarre problem with my mobo and I wondered if anyone else had experienced the same. I'd originally built my system with a MSI GeForce4 Ti4200. Worked great, but I recently decided I wanted a bit more punch in the video dept and got myself a VisionTek XTasy 9600 256mb card. Slap it in the machine. Push the power button.
For about two tenths of a second the machine begins to power up normally (fans start, light on, etc.). Then no poweron for me, dead board (well, just unpowered. The "power's getting to me" LED is still on). However, if the power button is held for 5 seconds (to force a powerdown) and then pressed again, the machine will once again attempt to power on. Hence I don't think something's wrong with my power button.
Things that make the machine power on:
Putting in the old video card returns everything to "works just fine" state
QUICKLY cycling power (if the machine is off for more then three seconds it's not coming back, otherwise it's OK)
Flashing the BIOS with the latest version and erasing the CMOS before restart will allow the machine to be powered on. However once the CMOS is written the machine will NOT power on until it is erased once more. I haven't tried this with the jumper setting yet, only software erase.
(X-Treme Stupidity technique) Putting in the old video card, powering on (booting to BIOS), ripping the card out while the machine is on, putting the new card in while the machine is still on, QUICKLY cycling power.
Things I've tested:
The new video card, when it's in and the machine is on, works just perfectly.
I have purchaced a similar card (ATI branded Radeon 9600XT 128mb) and had the same problem.
I have checked the voltages and my system appears to be recieving ample amounts of power.
I talked to ASUS and they offered two explanations. One was some weird EMI issue..which I guess COULD be the case...the other was a defective board or a short caused by board-case contact. Both of these sound a bit odd as I'm not sure what the difference would be simply POSTing with the two different video cards that the issue would affect one and not the other.
So yeah, I'm definitely curious as to whether anyone else has any light to shed on this. It's a pretty bizarre issue. On the up-side, I've found out I can mess with my hardware quite extensively while my machine is still on
. Down-side is I think that's probably a generally bad idea. My financial resources are rather limited so simply picking up a new mobo isn't an option....can anyone think of anything that could be causing this?
Things I've tested:
