p4p800 deluxe wont post
kennyc28
I have whats in my setup in it and I tried it with a 2.6c and it wont post just turns on all the fans.I have tried single stick and dual channel. Do you think the board is just bad?? I have tried reseting the bios too. Should it post even with no memory?
it won't post without the basics (cpu and ram).
The p4p800 has voice post, so plug some speakers into the speaker out jack and turn them up. When you turn the board on, you *should* hear why it's not turning on.
how do I know what beeps mean what?
thanks for that tip I am used to my abit board that shows a # on the led I already got an rma but I would still like to figure it out
it doesn't beep, it will tell you in plain english what it thinks is the problem. For instance, if you don't have a CPU installed in the socket, and turn the board on it will actually say "System Failed CPU Test", repeatedly until you turn the system off.
It's quite a nice feature if you're not quite sure what all the beep codes mean or have trouble discerning them.
If it doesn't tell you what the problem is and just beeps, you may try Asus' support site for the beep codes. However, no voice post either means it was disabled in the Bios before the problem occurred in the first place, or there's a very serious problem with the board that probably isn't related to your individual components.
thanks nts you have been a ton of help I am going to try it and see what it "tells" me lol I think thats funny but a good trick
no problem. I know how frustrating a problem can get...I had an Abit IS7 that would turn on, then shut off as soon as the post screen appeared. RMA'd that one for another IS7 that would wipe it's own bios constantly (brought up the recovery screen saying checksum was bad)...so I RMA'd that one for the p4p800-d I have now.
hope you get it sorted out.
I heard the voice post it said system failed CPU test in a funny korean like voice I tried 2 different cpu's so I guess the board is bad Oh well:rolleyes:
I ordered a p4c800 e deluxe thats what I wanted anyway I guess I will never buy a reburbished board again at least I got all my money back
The P4C800-E is a good board. You should be very happy with it.
