P4P800 deluxe not recognizing SATA?
StOCK
i'm sorry if this question has an obvious answer, but here it goes.
i can get my system(listed below) to inital post, but it wont recognize my 80gb Maxtor SATA drive. it's all plugged in, any ideas? thanks in advance.
system:
2.8c p4
512 geil ram 3200
80gb maxtor SATA
p4p800 deluxe
obviously no OS with no hd
-Ryan
EDIT- well now i got it to recognize it, but now it's as third drive...sorry folks!
are you trying to install windows on it or is that a secondary harddrive? or do you mean it wont reconize it in bios?
i'm trying to install windows on it, it's the primary.
right now it is recognized in the bios, but as the third drive(i only have one)
also, whenever i try to boot from the CD drive, it just goes straight to bios.
any help is greatly appreciated.
alright i got XP installed, but i still can't boot from the drive. on startup it goes straight to BIOS.
can you read anything it says on screen before it goes into bios? sometimes where there is some kind of hardware error it will go strait to bios.
If I'm thinking of your setup correctly, the SATA drive should show up as 3M (3rd Master, or 1st SATA connection). In your boot order in Bios, make sure that the one that says 3M is set to first drive.
I just sent my P4P800 off for RMA, otherwise I'd give you a screenshot of where I'm talking about. I had the same problem and setting the 3rd master drive as the primary in Bios solved it.
