knyghtryda
- Mar 27, 2004
I just upgraded from a Soyo p4x400 dragon platinum (good board, bad bad OC ability) to a p4p800. Everything was smooth until I booted up, when I found out that Windows wouldnt load. It got to the point of selecting whether I wanted a normal startup/ last good config/safe mode etc, and then it either goes black or it gives a BSOD with 0x0000007b followed by more hex. I pulled the drive, installed another one, and installed windows again. Everything now works fine. What I'm wondering is why the old OS setup wouldn't work. I read it has something to do some sort of OS/motherboard driver incompatiblity or something like that, but I uninstalled all soyo drivers and even ran sysprep (something I read would fix it). Nothing works. I haven't yet tested that drive on another board, but I'm wondering if there's any way to fix it without a format/reinstall.
