P4P800 and HIGH vcore overvolt
nst6563
As the title says, I have a p4p800d and for awhile I've noticed that the vcore is by default 1.63-1.69....and this is when the bios is set to 1.52v (default).
any clues on this???? my cpu doesn't seem to run hotter (around 95f on average)...but will be upgrading to a new cpu in the near future and was a little concerned at this. especially if I was to get a prescott since they use a lower voltage and are already hot.
is there a spot on the mb that I can read the vcore with a dmm?
its on all asus boards
every asus board overvolts, it just so happens that the p4p800 and the p4c800 overvolt and undervolt as well, only workaround is to physically mod the mobo (a droop mod i think fixes the issue)
mine is set to 1.6, it undervolts to 1.55 sometimes, or overvolts to 1.66, but i havent encountered any problems.
hopefully this can be fixed in a bios release, but its not likely, i think its a physical hardware issue that can only be resolved with a physical mod.
I googled the issue and found the droop mod. sooo....I took the plunge and did it. was REALLY easy. As long as you've got fairly steady hands, a lower wattage iron, a sharp point...and some good light...it's a piece of cake. Took me all of about 1 minute to solder the mod on. I simply used a 28k resistor since all the articles I found use a 50k vr/pot and set it to 28k.
so far, it still overvolts, however I haven't done any tests to see what the load voltage is like.
haven't tried to oc any farther either. Even if I got to 3.4Ghz with this chip...I probably wouldn't see a difference in speed other than benchmarks.
Does anyone have a mod to MANUALLY limit the vcore? Say, with the use of a VR/Pot? Like a vdimm/vagp mod? I would really much rather run my cpu at less than 1.66v all the time.
Even when set to 1.52 in bios it's running at 1.66v.
I'm tempted to RMA the board, but don't want to be out of my pc for that long...
I'm not intentionally running it at that voltage. That's what the bios/asusprobe/mbm5 are saying. I'm going to assume they're right, but haven't found where to measure the actual voltage that's going to the chip.
even with the higher voltage though, I can't oc the damned thing any higher. The chip is at it's limit. If I could get a full 1Ghz oc out of the chip at that voltage...I may not mind as much:p
yes, and that's what it's set at. Even though it's set at 1.52, it's 1.66-1.70 when idle. So, before the droop mod, (I figured what would it hurt) the difference between my idle temps and my load temps was almost the same.
I took a reading with a dmm at the mosfet legs and it is indeed feeding the cpu 1.7v.
I may just rma the thing...if I can do without a computer for that long:(
