P4P-800D reporting very high temps
Talon
I have a friend who recently purchased an Asus P4P-800 Deluxe and an Intel Northwood 3.0C. Since he recieved the hardware from NewEgg his Asus board has been repeatedly shutting down, and after some checking in the BIOS immediately afterwords showed the CPU temperature being reported at 87 Celc after runing for 45 seconds.
He was using the retail HSF included with the retail CPU and some generic thermal paste. He checked to make sure the HSF was on right, chip settins were correct, etc, and when that failed to help, ordered a new HSF (can't remember what kind at the moment, one of the better Vantec ones) and that dropped his temps to 65C right after boot. Still way to high. When he applied the Artic Silver the temps jumped back up to 73C.
He tested the board while running with an external thermal probe and found out that while the board is reporting rediculously high temps, the probe only called it 39C. Touching the CPU directly after shutting down and removing the HSF (around 30 seconds) leaves the chip only feeling warm to the touch, even though the board reported the chip running at 70+C.
At this point I'm fairly certain that the temp sensor on the board is giving bad readings. Has anyone else ever heard of this and possibly any fixes for it?
I know I'm still a cheeze, but there should be a setting in the bios under hardware monitor that allows the user to uncheck certain readings. I'm not familiar with the p4p800 yet (mine's coming), but my current p4t533-c allows for bypassing temperature settings as well as fan settings.
That is that you and your friend are absolutely certain that the motherboard is giving a false reading.
Have you tried updating the bios? (just wondering)
Chuck
Since when does post count determine computer knowledge? ;)
Yeah, I know we can disable the automatic shutdown, I think he already has, in fact, but he also wants to fix the problem.
I recomended updating the BIOS to him; I'm not sure if he has yet. Hopefully that will fix it, but I'm not convinced.
