deerslayer65
- Dec 4, 2010
Ive got an asus p4c800e mobo that recently my video crapped out when my CRT was replaced with a 22" flatscreen. Was using an Antec true power 480watt PS, but with limited stuff on the rails. The video card is a NVIDIA 6200 EGA with .5 GB ram. It recommends a 500Watt min PS. It works ok, but I would like to add the 4 IDE ATA100 hard disks I use for video editing.
With the bare configuration I upgraded to a Thermaltake 750watt PS (1 rail not 4) however the board is very unstable and reboots frequently. I went back to the Antec and everything is fine again. Thinking it was the Thermaltake, I upgraded to a 1200watt BFG - one rail PS and got the same results, which is hard to believe.
Which leads me to me question, Is the p4c800e have a max limit PS it will accept? I have also heard the caps on these boards dry up and go bad, mine was obtained in July 2005. Other than the above issues the system has been rock solid for 5+ years.
Asus p4c800e
4GB ddr ram
2 - 80GB ATA100 drives
NVIDIA GTS 6200 .5GB ram EVGA
p4 3.2GHZ HT
22" Flatscreen ACER
Win XP Profefssional 32bit
Win 2000 (2nd drive)
Wanting to hook up - 4 IDE ATA100 drives ranging from 80 -170 gb each. (used to have these hooked up through an Adaptec PCI controller card.
Asus p4c800e
4GB ddr ram
p4 3.2GHZ HT
22" Flatscreen ACER
