P4c800-e volt mod and droop mod needed?
sierra248
Well I've been playing around with this thing all week and here is what I've decided to leave it, as its stable for 72hours at 100% CPU usage with CPU temps never climbing above 108 Degrees(42 Degrees Celcius). This is the highest OC I can do without going over running over 1.7volts. I'm a little disappointed with the overclock as I paid allot for this SL6Z5 but it runs good and stable.
Asus P4c800-E with P4 2.8C SL6Z5
Antec 430Watt with 2 fans
2x512 OCZ PC3700EB
Antec p160 Aluminum Case
Thermalright SP-94 with 92mm Tornado(Artic Silver)
Thermalright NB-1 with small fan that came with it(Artic Silver)
120MM Stealth Front Intake Fan
120MM Stealth Rear Exhaust Fan
Configuration System Frequency/Voltage
AI Overclock Tuner @Manual
CPU External Frequency @230
DRAM Frequency @400 Mhz
AGP/PCI Frequency @66.66/33.33
CPU Core Voltage @1.6000Volts
DDR Reference Voltage @2.85Volts
AGP VDDQ @1.60V
Performance Mode @Turbo
CPU INFO
CPUID Maximum Value Limit @Disabled
Hyper Threading Technology @Enabled
Advance Memory
Configure DRAM Timing by SPD @Disabled
DRAM CAS Latency @3.0 Clocks
DRAM RAS Precharge @2 Clocks
DRAM RAS to CAS Delay @3 Clocks
DRAM Precharge Delay @5 Clocks
DRAM Burst Length @4 Clocks
Performance Acceleration Mode @Enabled
DRAM Idle Timer @AUTO
DRAM Refresh Rate @AUTO
Graphics Aperture Priority @AGP/PCI
Graphics Aperture Size @128MB
Spread Spectrum @Enabled
ICH Delayed Transaction @Enabled
MPS Revision @1.4
Advanced PCI/PnP Settings
Plug and Play OS @YNo
PCI Latency Timer @64
Allocate IRQ to PCI VGA @NO
Pallette Snooping @Disabled
PCI IDE Busmaster @Enabled
Anyone see anything wrong with that? It runs good and Seems to benchmark well. I have no way of posting screenshots right now but I will ASAP. Here is what I get from the Sandra Memory Bandwidth Benchmark:
RAM Bandwidth Int Buff'd iSSE2 = 447MB/s RAM Bandwidth Float Buff'd iSSE2 = 5421 MB/s
3dmark2003 = 1955 with Geforce 4 ti4200 @300/600 MHZ (I know that sucks, new video card coming soon)
Well any comments or suggestions would be greatly appreciated, I'm dissapointed that I couldn't run DDR500 as I had expected but Maybe I'll get the OCZ Booster and run 2.5-2-2 and speed it up a little more.
Thanks Guys its finally done
Tom
