P4C800-E Deluxe Memory Issues
lelliott731
[H]ard DCOTM April 2017
I own a Asus P4C800-E Deluxe motherboard, with a 2.8GHz Prescott P4 and 1GB (2x512MB) PC4000 OCZ memory. I currently have the processor running at 3.36GHz, but my memory is only running at 160MHz or 320MHz DDR. I can't seem to find any ratio adjustments in the BIOS. The only DRAM speed info I saw had 266MHz, 333MHz, and 400MHz. Is there something I'm missing? I thought this board was like the best possible board for overclocking? I had a IC7-MAX3 before this, and I got this thinking it might be better, but if there is no memory divisor adjustments, then that severely limits it's potential. Any help would be greatly appreciated!
Hi, just set the ratio to 400mhz. This is equal to 1:1 on your board. This should get you running 1:1. If you need additional help PM me and I'll give you some contact info.
