P4C800-E Deluxe & 9800xt Problem
Outcompute_123
Hey guys.
In the middle of building another box here, and running into a problem using the Asus P4c800E-Deluxe as stated in the topic. There is ALWAYS something wrong at least once with these boards.. Grr.
The problem is coming when trying to boot the system while an Ati Radeon 9800xt is in the agp slot. I've gotten the system to post, give a video feed, and boot up to windows, no problem when using an old OLD video card, but not the xt. So, the problem is narrowed down to the video card/agp slot. (The xt, I might add, works. There isn't a problem with it in other rigs.)
When the xt is installed in the agp slot, the mobo led will light, but no power circulates. The system doesn't turn on via the power switch. No fans power, No hard drives power, etc, no post, no beeps, no nothing. Just the Led.
Wasn't any info about a particular problem like this on the forums, so I decided to post and start up an info hunt.
Any help, info, anecdotes and the like, would be appreciated.
I've learned that p4c800-e deluxe's don't support 3.3v agp cards. That was news to me.
However, the 9800xt is 1.5v, so I remain stumped. And the system remains not powering up.
The 9800xt is definitely causing the mobo to not power up anything. Let me know if you or anyone has had this happen also.
Yeah actually I think my P4C800 Deluxe says it under the AGP slot. I know the manual says it at least.
This may sound retarded but have you plugged power into the 9800? It does need a seperate 12v line run to it.
Also what is the spec of your power supply? How many devices are attached to the system?
Thanks for the reply Frag.
I dunno what to do really. Every p4c800-e dlx board I get, I wind up having to @%$% Rma. I'd like to not have to do that this time around.
Only thing I can say is that the working video cards that the board accepts and powers on with, have 2 separations in the agp pins. The Xt only has one separation in the pins.
I know -someone- has had a problem like this too.
Surprised EVERYONE doesnt have the same problem the way asus' bats 1.000.
"Nothing works in here, I hate this place. I've been here seven years."
If you can get into bios....turn on and off a couple of times then press delete key....once your in the bios....Jumperfree settings Performance mode set it to "AUTO" then AGP VDDQ to "1.6V" if all things doesnt works...try tweaking your ram timings maybe the board doesnt like your timing....I ussually have this problem when i clocked too far...sometimes it wont turn on un you reset the CMOS...
Peace.
henessey
heh im runnin an XT in mine right now... no problems here... my x800 is in RMA... damn flash mod
Hey Henney,
I tried the ram timings already, but didnt think of manually setting the vddq.
Upon trying it, there was no help to it. I kind of suspected that would be the case, but i'll try anything once.
The board still seems to short out when that xt is in the agp slot. Never fails.
Dropped asus an rma notice, they'll probably get it by Tuesday. Those bastards. So much for my weekend project here. (Well, I guess it can be considered a complete project now.. WITH A GEFORCE 2 IN IT!!!! Echhhh.)
I inquired whether or not they would test the mobo with the same type of card to ensure Im not in a state of perpetual rma with them. The answer will probably be no.
I'm still on a mission to not let this problem fall under the category of "Unsolved- Cause/Effects-so-lets-just-RMA-and-not-care" Fug that, I need to know.
And Amb. No thread jacking!! ;p
(aka... what went wrong with the flash mang? :p)
I have the same MB and a BBA 9800XT with no problems at all. This is the second P4C800E-DLX I've had. My guess would be your PSU. Can you check your rails on it? In the BIOS try the VDDQ @1.7 ,make sure video is set to AGP and disable assign IRQ to PCI Vid. It may help. Go check over at ABX. I think I remember people having poblems with that MB and the Asus XT.
This may seem obvious, but don't tighten the AGP slot screw on the side of the case and make sure the card is completely in the slot. I have a Ti4400 that doesn't quite line up to put a screw in and I have to use a cable tie. Just one more thing to make absolutely sure of. :cool:
You could also try asking at the Intelforums and see if anyone there knows.
