???? - MSI P45 Neo3 V2 [-IEEE1394]
-??? - MSI P45 Neo3-F [-IEEE1394]
-110 - MSI P45 Neo3-FR [-IEEE1394] (PCB 1.1)
-??? - MSI P45 Neo3-FIR
???? - MSI P45 Neo2 [-IEEE1394]
130 - MSI P45 Neo2-FR [-IEEE1394]
???? - MSI P45 Neo2-2FR [-IEEE1394]
+??? - MSI P45 Neo2-FIR
+164 - MSI P45 Platinum
140 - DFI Lanparty DK P45-T2RS PLUS
190 - DFI Lanparty UT P45-T2RS
NOTE: Board/models that are highlighted, theyre not on sale anywhere in the US.
I am trying to pick out 2 P45 boards from the list above. I have several questions:
Q1. Which of the boards will work with 2 x 4GB [total 8GB], 4 x 2GB [total 8GB] & 4 x 4GB [total 16GB] RAM configurations? If yes, can you recommend specific make/model?
Q2. Can DDR2-1066 or DDR2-1200 work in the module/density configurations as stated in Q1? Recommend any specific make/model?
Q3. Module, density & speed configurations from Q1 & Q2, will I need to up the voltage on NB, RAM or other MB components? If yes, can you provide specifics?
Q4. Which boards support Memory Address Remapping in BIOS?
Q5. Which boards support ATAPI/optical [CD/DVD] devices on the 2 extra SATA ports [7 & 8], provided with JMicron JMB363?
Q6. Are these SATA ports [7 & 8] bootable; can the system boot from ATAPI/optical devices attached to these ports?
Thank you, in advance for any help.
