vat said:Thank you for the replies, I am not comparing P-M to Celeron-M but I am comparing P-4 vs Celeron. I have heard somewhere that Celeron-M is a little better than P-4. I don't know if that's true but I have someone could clarify that for me. Thanks
Yiffy said:I'm assuming you made a typo at the end of that first sentence and meant to say "Celeron M" (otherwise the first sentence contradicts the second and the thread title).
It really depends what models you're comparing between the Celeron M and P4 and what you're doing. But for general use I'd say the Celeron M is better suited for a mobile setup than a P4 (or even a P4-M for that matter).
vat said:Yes, you are correct, that was a typo. So I would be better off to get Celeron-M if I only use it for like Microsoft Office, watch DVDs, burn Cds, ect...? What's the benefit if you get P-M over Celeron-M? What P-M can do that Celeron can't do? I hope I am not asking to much, thank you.
Yiffy said:And there are faster Celeron M models too.
perplex said:how would a celeron M compare with xp 2400+ ?
ZenOps said:The Pentium M does have speedstep, the Celeron M does not.
That does not mean the Pentium M consumes less power. Pentium M Dothans at their rated speeds uses about 1.34 volts. A Celeron M Dothan uses 1.26 volts at rated speed.
If you run your laptop at high CPU usage most of the time, the Celeron M actually will have lower power consumption than the Pentium M chip. If you laptop idles a lot, the Pentium M will have lower power consumption because it can step down to 0.988 volts and 600mhz fairly quickly. In general use though, they are very similar in power draw.
Its an undocumented feature, but you can *startup* a celeron M at 0.700 volts 600mhz and it will always consume less power than a Pentium M (as long as its not a LV or ULV model) unfortunately it will be stuck at that speed as it does not have the circuitry to ramp up to full speed and voltage.
Blinkme323 said:Some guy on Anandtech sells Celeron M's overclocked to 200 bus and 3.2ghz. He uses Asus mobo's and sells the combos very cheap. How would these stack up. He is Karaktu I think, his combos are famous.
Yiffy said:So you can use a 6X multiplier on a Celeron M? Any links to this?
Talonz said:Disable speedstep in the BIOS and the Banias will go to a 6x multiplier (600mhz). I bet the C-Ms will do the same with that process
markku said:sorry but celerons have only one multiplier..
no 6x or whatsoever.
as also first pentium Ms were banias then naturally they had mults down do 6x..
ZenOps said:Its an undocumented feature, but you can *startup* a celeron M at 0.700 volts 600mhz and it will always consume less power than a Pentium M (as long as its not a LV or ULV model) unfortunately it will be stuck at that speed as it does not have the circuitry to ramp up to full speed and voltage.
markku said:bought a cm 360J for ~35 bucks recently and did a little comparison pm vs cm, both at 2240MHz:
3dmark2001SE, cm 18820, pm 20135
superpi1M, cm 38.265sec, pm 34.029sec
superpi8M, cm 7min 53.250, pm 7min 08.076
hecus pifast, cm 54.54, pm 52.62
i always thought that cm performs just like banias, but it actually is just a bit worse.
the reason - like always with celerons, there's more to it than just smaller L2 cache -
whereas pm has l2 with 8-way assiociativity, cm has 4-way..
and that is the main reason celeron is slower, not the size of cache..
i could manage to oc celeron M all the way to 14x166(2324), with 1.3v and stock ct-479 cooler and it wouldn't oc not a single mhz further.. not even boot...
actually most of the celerons have 166 fsb limit.. those few 180s are quite rare..
cm now sits passively, using ct479 hs with no fan plugged in, in antec minuet case, on p4p800vm at 2.1ghz.. prime stable of course![]()
mine is C0 too..R550?_G550! said:The Celeron M I got is revision C0, just like those PM 7x0 's
That's why it can sustain a higher FSB.
