I'm overclocking my P4 2.8C and naturaly i'm trying to get most out of the chip without passing the 1.7V mark as is always recomended. The problem I'm having is that, according to MBM5 and CPUZ atleast... when the cpu is idle it runs at about 0.8V higher than the bios setting. When it goes to load i.e. HL2 or Prime95 then it drops instantly to the bios set voltage.
Should I keep my idle voltage at this 1.7V line to be safe? Or should I make my actual voltage hit around there if needed since theres not much heat output during idle anyways?
On a side note, I noticed my case/cpu temps idle are 31/34 and load its 33/44. Is this big difference normal and how much of a jump should I get when I switch from stock HSF to XP-90 with Panaflo?
Thanks,
Eric
Thanks,
Eric
