P4 Threshold temps.
MTXR
So what are the temps to watch out for, for a P4 2.4c
How much heat can these things take?
Currently at 140F CPU, 107F CHipset, and 95F case is what mbm5 is telling me.
edit: THose temps are at 100% load.
P42.4C @ 2.8
i am overclocking my Dell 400SC :p
things are holding at 140F now to see if i get any errors.
I think i will keep it at 2.8 cause the damn temp sensing fan is spinning up to a noise level i can just barely deal with.
I didn't think Dell computers could be overclocked, but i guess i was wrong.
Some quick mental math tells me thats around 45C which is fine. Your other temps are accordingly lower so I doubt there's a problem.
In the future however I'd suggest using Celsius, as most people do now for these things.
If your fan is too loud, you could try replacing it with a more efficient one, if you're using the stock Dell fan I bet you could find something a little better.
140F = 60C
Maximum Temperature in Celcius for 2.4C = 74C
I should be good i guess..
Well my quick mental math was wrong. :p
edit: now that i think about it, that did seem low
