blindrocket
- Jan 14, 2001
I'm here at work with only a couple of hours left in the day so this is rather urgent.
Our P4 2.8 system wouldn't start up the other day so I ordered a new PSU off of newegg.
It arrived today so I installed it, everything seemed to go fine and it fixed the power problem but now it won't boot into windows.
During post it seems to detect the CPU, the ram, and the CDROM but it doesn't display the HDD.
I went into setup and didn't see anything out of the ordinary either. I put in the Windows XP disc to see if it would boot from there and it will not.
Here are the specs:
P4 2.8
Intel Desktop Motherboard (I'm not sure the model, no PCI-E but it does have SATA)
1 GIG DDR333
120 GB WD HDD IDE
Any help would be greatly appreciated, I already cleared CMOS, reset the Molex connectors but I'm kind of stuck on this one.
Thanks!
Here are the specs:
P4 2.8
1 GIG DDR333
120 GB WD HDD IDE
Thanks!
