DarkHelmet
- Jul 8, 2004
Setup:
AOpen AX4G-N
2.4 Northwood not OC
Stock HSF
I am a little worried right now because I installed MBM and it is telling me my CPU is running at 96C and my case is at 74C and the CPU kernel is at 74C.
I'm assumed this was a wrong reading since the tempature monitor that came with my Mobo (HardWare Monitor 3) tells me my cpu is running at 45C under no load. Also my exact Mobo model is not one of the options when configuring MBM. Since I got a weird reading with MBM i decided to try speedfan. Speedfan tells me the same thing as MBM. Are my temps actually that high? I was planning on getting the Thermaltake P4 Spark 7+ HSF once I start over clocking but if my CPU is actually running that high....might need to get one sooner then I thought.
I also have 4 80mm case fans, so I thought they would take some heat out. My cables are a little messy and could probably be cleaned up to provide better circulation. But 96C? I thought it would shut itself down at that temp or just fry itself. Thanx for the help.
EDIT: Also, under my BIOS it tells me my CPU is 43/44C.
AOpen AX4G-N
Stock HSF
