P4 Prescott 540 vs. 540J
Tobit
[H]ard|DCer of the Month - March 2010/May 2011
Anyone know what the differences are between a 540 and a 540J Prescott? I've read on one website that the J simply indicates support for Intel’s Execute Disable Bit and that there is nothing else different.
I'm thinking of putting one in a P45 chipset moterboard for now for a couple months when I will later upgrade to a Quad core. However, although the motherboard specifications (GB GA-EP45-UD3P) states that the 540 is supported, the 540J is only listed as "Under Testing". This leaves me a bit skeptical as to whether the 540J will work or not.
Any ideas? Thanks.
They are virtually identical except the EXD bit. I'd say it is impossible for the 540 to work and 540J not to.
Have to agree with savantu. I had that issue similar to you and settled with the 540 simply due to it being cheaper at that time. Unless you absolutely needed XD bit, both processors are the same.
