P4 Power connector not needed???
kockblocker1
I just changed my power supply in my PC. I had a cheepo compusa and I just replaced it with a 600w I got from Zipzoomfly. My motherboard is an ABIT AI7. The new PS I bought didn't have a p4 connector. I pluged everything up and powered on my system. Everything is working fine. My 3.06 is running at 3.2 just fine. It has been running looping 3dmark for the past 15 mintues.
Are the p4 powerconnectors needed anymore? Whats going on here???
:confused: :confused:
You are pushing your luck, and it sooner or later you’ll have a problem with your ATX power connector. The 20 pin ATX power connector only has one 12V pin and it is rated for 6 Amps and your P4 can draw up to 8 Amps or more under load. Over time the current overload will lead to a poor connection that get hot enough to melt the plastic connector housing and drop enough voltage that your computer will stop working. I suggest you find a 4-Pin drive to P4 adapter cable ASAP if you want to keep that power supply.
Guess I should have fricken checked the box. Reason I didn't plug in the P4 Power connector is because I didn't see any. I found an adapter in the box to turn the 8 pin power connector into the 4 pin that my MB uses. Thanks for the input dude. I would have defentately screwed my system up if you didn't give me that warning.
2 thumbs up to HardForums ;) ;)
