p4 overclock helP
Irishllama
Ok i got another comp, a p4 1.6 ghz, i think it's william----- sumthing...
Well Im not sure if im doing something wrong, but one question i have is, cpu z, says multipliar is at 16.... and BIOS says 8... and when i try to change it to 10 in bios, and my mem, up 33 mhz, it just restarts, and resets the entry back to 8. And help would be good.... thanks.
The multiplier is 16. You can't change it. You probably won't be getting much of an overclock out of it anyway if it is a willy.
