Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
They do yes, (but a quick search on google should have revealed that for you)... P4M have speedstep built in and so only run @ 12x multiplier on desktop boards, I've had plenty and the later D0 stepping work best and I used to run them between 3.0Ghz and 3.6Ghz like that a couple of years back, Mobile Celerons are better if you ask me as they don't have speedstep on them and so don't require such silly bus speeds plus they are dirt cheap off Ebay. Get a D0 stepping and go for it.
As always stepping is pot luck, but a resonable guide... I've had C1s do 3.5Ghz and D0s stop @ 3.2Ghz, so no guarentees....But the general rule, the later the chip the better.
