Hey guys,
I'd like to know your opinions on the max voltage that should be put on a D1 stepping p4 on air to avoid NSDS risk.
I'm running a 2.4c cooled by a sp94, as5 and a vaccumish 92mm tornado on an ic7-max3 with Corsair Twinx4400.
I'm currently stable at 250fsb, 1.625V and I don't think I should be worring too much about my current temps(~31*C/~42*C). I'm wondering if raising the voltage will be worth the few extra mhz or if the NSDS risk willl be to high. So how much do you think is safe?
Thanks!
Thanks!
