Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Usually if your processor is not connected properly it will beep. My computer does not beep unless i take the processor completely out. Can the processor still be detected and faulty, therefor not beep?
weve used two different mobos and also 3 diff vid card (agp,pci) And we still cant get a video signal. Tried 3 diff types of pc2700 ram as well. Ive previously built a computer with the same exact components so I dont know the problem.
Do you have access to another chip? try a known good chip in the board see it it boots. If it doesnt obviously you are doing something wrong. If it does boot up then you have a bad chip.
