I recently built myself a system and ever since I have been having problems with lock-ups. It was really bad before, and then I swapped out the memory twice (second gig set was as bad as the first) and now it has a lot less problems. It will still occasionaly have issues though. I have had a couple times where I am playing UT2004 at full everything, 1680x1050, encoding a DVD, or various other things where the system will just freeze. It's much less common now (I can usually play UT with no problems, etc.). I have thought maybe the cpu is overheating since it has the stock cooler, but temps seem to be 65-70 when I check in bios (after reboot). This is hot, but it shouldn't be overwhelming. I also only have two 80mm fans in the case (one in and one out) but it shouldn't be too bad. The system is as follows:
P4 670
Intel 925XE
512mb DDR2 (Garbage Centon being replaced by OCZ this week)
ATI X800XL 256
Does it seem like it's overheating or am I looking at another issue with the motherboard, proc, or memory?
P4 670
Intel 925XE
ATI X800XL 256
