P4 550 blazing hot!!! HELP
Travagin
Just wondering if anyone uses a Zalman 7000 copper cooler on an LGA system?
If so what speed?
NOTE: thats 7000 not 7700
Just to let you know that the 2 intel p4 550 3.4ghz cpus ive had both D0 rev have run very hot on air. As long as the chips stay under the 70C throttle temp, and the system is stable, then your ok. But what temps are you very worried about, and whats ur full system spec
My 550 would run at about 70c on an arctic cooler, but I now have a thermalright 90c and it stays around 51c.
