Peach said:I agree, the features of the prescott are nicer than the northwoods, but the northwoods do OC alot better than the prescotts. I would buy the prescott if it was say, 4 months ago, but I would just save the money you would spend for the 3.4 and put it towards your smithfield upgrade like im doing![]()
Peach said:I notice a difference between a 2.8c northwood and a 2.8 pressy, i mean, prescott, because of the cache.
chrisf6969 said:D1 stepping 3.0C - I would think you could hit 3.4Ghz easily, which will out perform a prescott at the same speed. Northwoods clock for clock are faster than Prescotts.
I agree with the recommendation to get better RAM. 3-4-4-7 is just about as loose as RAM timings go - and you needed to run at those timings just for stock-speed operation. That leaves you very little room for OC'ing - you might not be able to OC your FSB past 208MHz (832MHz effective) with that memory.rawd said:Ok thanks guys, I will keep the 3.0c. I put this system together in order to OC at a later date
BigBadBiologist, CPUID reports my stepping is Family F, Model 2, Stepping 9, Revision D1
I purchased 2x512 Corsair pc4000 twinx, timings are 3-4-4-7. Mobo is Ic7 Max3
I'll give it a go this weekend, any pointers before i get going? ive been told not to push vcore past 1.7
PS. I have air cooling, Zalman Cu/Alum heatsink
