P4 3.0 Ghz Prescott
60c isnt unheard of for that prescott, I really wouldnt worry about it unless your having issues.
I had a 3.0E and it would routinely hit 61 degrees with the stock cooler under load. I occasionlly saw 63 during the summer. I would most certainly change the HSF if I still possessed that flamethrower.
The cooler you detailed while good when introduced, has been eclipsed by the likes of the 9500 and similar high performance coolers.
Good luck.
