My Cpu is idleing at around 35-40 C but when I play a game of any kind, or a demo it go's up to around 55-60 C.
I am running the stock heatsink and fan, running at stock speeds.
Is this temp normal?
My system is listed in my Sig and it is correct.
My case is a thermaltake with the fan on top, and two on the side, plus the front and rear fans. All are on, and of course I have fan controls for my casefans but even if I crank them it makes no difference.
This is my temp after playing three loops in the ati chimp demo, to give you a idea.
Let me know what you think.
If I need an better Cooler, I want somthing fairly quite.
Thanks
Roger
Thanks
Roger
