P4 2.8c Overclocking - Advice Need Please
morpheus9394
I am trying to overclock my P4 28c and whatever speeds I select, even lowish speeds, it does go past post tests.
The lowest settings I've tried where:
225fsb
7.2.1 ratio for CPU/AGP/PCI
Memory at 5:4 ratio
Voltages at default.
System specs are:
P4 2.8C
Corsair 3200LL (with heat spreaders)
ABIT IC7 MB
SATA Seagate HDD Boot Drive
WD IDE drive
CDROM + CDRW
Heat is not a problem as I have an Akasa King Copper cooler and 6x 80mm case fans.
Depending at what settigns I use, either the SATA drive is lost during Device detection or all devices are found but the PC hangs at that point, though a soft reset works fine.
I've tried increasing voltages for CPU, AGP and DRAM and changing the ratios etc but still no luck.
Any ideas would be appreciated.
Thanks in advance.
