P35 Mb suffer from 4 memory modules?
doox00
Thinking of upping from 4gb (2x2gb) to 4x2gb modules of ddr2 for 8gb total, does this effect performance/oc. I know in the past 4 modules could cause issues with ocing.
It didn't affect the OC of my board, but I did have to leave the seetings on AUTO instead of manually setting them. Haven't taken the time to see what I can adjust.
My modules aren't the same size nor are they the same brand though, so that might affect my setup a bit.
okay, thanks.. think I will pick up a couple more gigs then
