I am building a mini-ITX system to eventually go into a homebuilt or case mod. Haven't decided on the mod yet, but it will have adequate airflow.
I am debating between these systems. Both have similarly equipped motherboards, and both will be able to be made very quiet. The differences are going to be in motherboard support, performance, overall cost, and cooling requirements.
Either system:
512MB memory, appropriate for system $60
40GB Maxtor HDD with fluid bearings $50
P3 system:
Pentium III Tualatin 1.2GHz $80
Freetech P6215 socket 370/FC-PGA2 motherboard $95
enough fans: $20
C3 system:
VIA C3 Nehemiah 1GHz, soldered down
VIA M10000A motherboard $150
enough fans: $10
I am aware of the Celeron/P4 mini-ITX boards, but they are beyond my budget and in my estimation would require way too much cooling for this project. I am also aware of watercooling---beyond both budget and interest for now.
So... the P3 system will have probably twice the performance, will cost an extra $30 or so, and will likely require more fans and as a result will be louder. I believe Freetech is the only manufacturer with a mini-ITX sized motherboard for the Tualatin. Any less performance than that would probably simply lead me to the C3.
The C3 system is very slick, nearly ubiquitous among first-time case modders, and VIA's support for them is well known. There is no upgrade path, though there wouldn't be much of one with my P3 system either. It would be very, very quiet. However, the performance would be even less than a Celeron of similar clock speed. I want the system to be useful as well as small.
Thoughts and opinions are much appreciated!
thanks
Either system:
P3 system:
enough fans: $20
C3 system:
enough fans: $10
thanks
