P3 keychain
ycchan
I dunno where to post this so I thought I put it here.
I got an old P3 733 CPU which I dont' use anymore and I was thinking of making it into a keychain, since I don't have a decent one. So how do you actually make one?
Pull the pins out, how about the hole for the key? Do I just use a screwdriver?
yes Im bored lol
i unfortunately fried an athlon xp 2100+ (i think it was a 2100) and decided to make a keychain. i managed to get all the pins off with large pliers, got several pins at once. it took quite a while though. i just used a regular drill to make a hole.
yes Im bored lol
if its still a working cpu and your wanting to destroy it to make a keychain your a moron, however if its dead and you wanna make a keychain out of it, i would follow tims advice your gonna need a drill of some sort to get through the cpu as its not as flimsy as it looks. As for the pins you should be able to just use pliers.
that's a good point. i only made mine a keychain since i fried it. i still have a (presumably) perfectly good thunderbird 1.1ghz around here somewhere. then again since that's the ceramic stuff it may not make a very good keychain.
