Here is the deal, my fileserver gets hammered at the LAN I help host, reducing its output to 23MB/sec. Since the network is all gigabit, I'm thinking that the best way to maximize throughput would be to have a private P2P setup just for the LAN. This would help immensely with the distrobution of maps, patches, and mods.
What I am thinking about is using Padlock SL, since it is based on waste and has a working linux client (the fileserver is FedoraCore5 x64).
Now, I've never used WASTE, so I don't know if it does the following:
-Allows a file/folder listing from a peer of choice(In this case being the fileserver), not search only (Files and folders is important, I would like it to be just like pulling it off Samba, but distributed.).
-Downloading is distributed. (Client will pull parts of the file from more than one peer in order to maximize throughput.)
Am I taking the right approach for a (free) solution to my problem?
