p2.x overclocking and voltages...
Syphon Filter
Hi there,
I see lots of people OCing the p4 2.X proccies to high speeds, like 2.8's to 3.5, 2.6 to 3.4 that kinda generally level of OC...now it seems a lot of people are managing these kinda OC's at stock voltages...to get my 2.8 to 3.5 i have to run it at 1.625 volts...this means higher temps...
are there some settings i need to tweak to get it to OC stable with stock voltages? Or is just luck of the draw....
I think its just the luck of the draw, could be wrong though, however my 2.4c is running at 3.0 at stock voltage :confused:
