P183 Fanmod
Phyltre
After doing quite a bit of reading, and pulling the trigger on a fresh P183, I've contracted mod fever. My goal is to take this mid-range case with great construction to the next level of silence--while maintaining airflow (and using even more fans.)
My focus will be on the upper panel lid. Any time you have a discussion of silent cases, the limitation of direct noise is always brought up. And anyone who has seen a P193 knows that its side fan has been baffled for just this reason. I will extend this design idea to the top of the P183, and see what the results are. If there is a meaningful noise improvement, I will do the same to the fan at the rear of the case.
Of course, what will really make or break this is the parts. I recently stumbled over A.C. Ryan's case parts and will be putting them to good use. Namely, I will be using one black aluminum panel as the top of the baffle, (trimmed to size, of course) and I will Acoustipack (this will also be used inside the case) its surface facing the fans to reduce bounce and absorb some of the noise. I will use the screws and HDD standoffs from the Constructx suite--both to space between the baffle and the case, and to attach the baffle internally.
There should be room between the sandwich for airflow, but I realize that not having an absolutely direct path may limit it somewhat. I have a plan to counteract that. Below the baffle, I will install two 140mm Noctua NF-P14 FLX fans (these should be entering the retail channel right now) in place of the one 120mm fan. There appears to be plenty of space so I would just need to Dremel a hole in the upper surface; I could also remove the grill up there since I will have something over the top of the fans anyway.
Anyone see any problems with this plan? Any feedback or concerns?
