I have seen a lot of you using the P180 case.
Ok just picked up one and getting a neo 550 ps.
Will the 4 pin 12v lead reach the top of the motheboard or will I need
an extension?
in the lower bay, I have 2 320G WD drives and need a boot drive as well.
How will the temps be if I put a 150 raptor in there as well.
Can the stock config with the 120 pulling air keep these 3 cool ?
and have you figured out a way to put in a 120 front in lower section without removing the bracket? I dont' mind doing that but how do you retain the lower drive cage?
thanks big time for info and since I have 2 weeks probably before my mb and cpu get here I have time to do stuff in preparation
sparks
an extension?
sparks
