Entropy1982
- Aug 6, 2005
Ok guys my P180 case should be here in a few days.
Here are the specs i'm thinking about:
X2 3800+
7800gtx
2X1gb ballistix
2 sata II drives
2 ide drives
Powerstream 520W
Zalman 9500 (if it turns out good) or xp90
I'm planning to OC everything pretty much so i want the best air cooling i can get.
So here are my questions:
#1 Do you guys think it would be worth modding the case to get a 2nd intake fan in the front as seen here: http://hardforum.com/showthread.php?t=939867&highlight=p180+mod
#2 What would be the best method of cooling the RAM (rubberbands?)?
#3 Is it worth buying a 80X15mm fan for the vga duct?
#4 I will be ordering a panaflo L1a 120mm fan for the front intake(s) and will leave the stock tricools, good plan? I have 2 fan controllers which can control 3 fans (cooldrive 6).
#5 anything i'm missing?
X2 3800+
7800gtx
2X1gb ballistix
2 sata II drives
2 ide drives
Powerstream 520W
