P180 Flimsy Case Hooks
Tov
Arg I read about how people were breaking those plastic hooks they use to attach the side pannel to the case and I swore I would be careful, but no, looks like they decided to break anyways. It wasn't like I was using unecissary force, the door was stuck and just would not come unhooked. I was wondering how readily antec will replace the door if anyone has any experience with this? Will monarch replace the door or the entire case?
Also, is the front door supposed to hold on with a simple magnet? I noticed the little magnetic circle piece pushes in a bit and makesa click noise but the just barely holds on.
On my antec p180 one of the side panels is very difficult to take on and off (despite nothing obstructing the hook holes and the panel laying flat against the case) , I have to force it each time. The hooks havent broken yet, but they probably will at some point. The front door is held closed with a magnet, i like this as it's very smooth to open and close the door.
