defuseme2k
- Oct 7, 2004
I modded mine and put a fan there in the front. I had to take some tin snips to it to remove some stuff that was in the way... Then I had to lap the casing of the 120mm fan I was putting in there so it would slide freely. Took a bit of work, but overall its going to be well worth it. The power supply sits too far inward to use the middle fan I've had two raptors die within a short time of each other. I had to do SOMETHING to get some cooling in there. I'll pull the drive cage out now that I'm back home, and will snap some pics later.
Who else has modded their p180 to put a fan down there? Post some pics, I want to compare what I did to what you've done.
