p180 build problem
smartis
I've just started a new build with the Antec P180 case and am having problems fitting the DVD Drives.
I'm using LG GSA-H10NBAL and having fitted the rails supplied with the case, the drives do not sit flush to the front of the case.
The best position leaves the front of the drive sticking out more than half an inch.
Are there any other rails that I can use or do I have any other options except to glue the rails to the drives in the right position or try and make up custom rails to make this work?
Thanks for any advice.
Look through all of the rails that came with the case, there should be some that allow you to adjust the depth.
Thanks for the reply.
Having re-read the manual and possibly seen the wood for the trees, it may be that this is USER ERROR and the rails are fitted the wrong way around. The holes in the drive bay seem ideally placed for the metal clips to snap into but I think that fitting the clips towards the front of the drive rather than the back may yield better results. Doh!
