g33zy said:Unfortunatly wire management varies a lot from case to case and also depending on the mobo and how many things you have attatched to the mobo.
Best advice, take a pic and post it. There are some cool guys in the rate my cables thread that will help you out. But first of all there are some things that you have to sort out first.
The first thing they are gonna tell you in there is to mount your hard drive with the plugs side hidden, basically reverse the way you mount it.
My advice too, be honest with yourself on what you "really" use. If you don't use many usb items, there is no need to plug in front usb connections because they just add to clutter. The rear usb connections are imo the worst thing you can have. They usually only have like 2 pots and the wires are thick and make a mess (usually the first thing you can get rid of to make it look better). You don't need to cut the unused wires, but just make sure you put them somewhere hidden and put a zip/twist tie around them to keep them in order.
The fan exhaust fan at the rear of the case can almost always be run under the mobo (and yes there is usually enough space under the mobo to fit molex plugs when they are flat)
On that "under the mobo" note, pretty much try to run as much as you can under there, its gonna depend on waht case you have but unused psu wires and that kinda stuff. There are some people who cut off unused wires but im not comfortable doing that so i just hide them.
Flat IDE cables are your friend too, they work very well because you can literally fold them right under the edge of the mobo and run them to where they need to go. Yeah the round ones are good for airflow, but thats only when they are exposed. The round ones don't usually fit very nicely under motherboards and don't fold as easy as flat ones. A good idea would be to get some black IDE cables (most likely from ASUS).
Spend some time looking around at your case and try different things then take pics and take advice from these guys here. We all @ the [H] been thru a lot of cases and helped a lot of people and believe me, we all had to start somewhere.
First case I ever wired up in my life was in about in Feb this year. Was it ever a piece of crap. Looked horrible, but as time passed and I tried different things (and different cases) it got better.
I also practiced a lot on other people's machines. Not many people have thier case wired very well so ask them to let you re-wire it for practice.
Heh, I even re-wired my work pc for the hell of it.
wow, that was long =) anyways, post some pics and i'll take a look at it....here are some pics of my progress.
Started out with a generic case that was a total nightmare (no pics of that one) Then I got the superlanboy:
I didn't post many of the detail shots of how I wired up the lanboy, but here's what I did when I got my P160
Here is the "rate my cables" shot from when I just got the P160 (notice the tape holding the PowerSupply wires)
_
And absolutely zero wires visible to the HDD
_
This is how they were routed, folded under the mobo and through a hole the tray, then taped along the rail so you won't see it from the other side. Where the arrow starts is where the hole is and where they come out.
_
The unused USB cables and the temp probes sit up here, they look pretty comfy and at least they have friends to keep them company![]()
_
The power and reset switches run from ALL the way up top behind the cages and like the IDE are taped along, behind a rail so you won't see them from the other side and they come out right under where they are to be plugged in.
_
Then I put in some sound dampening, got my x-fi sound card and a 36GB raptor and this is what she looks like now...
g33zy said:It's been an on going process. I got the P160 with the stock antec fans about a month ago. The case lighting was blue at stock. First thing was to change them because they weren't moving enough air and because the OCZ PowerStream power supply light was green so I decided to go with green Antec tri-cool fans.
g33zy said:So for a while I had the case all green with blue leds on the front and green through the mesh on the front, like how it is now. Only problem was the green was very boring. I had it like this for while until I ordered 2 blue 6 inch cathodes and 2 blue LED cannons and the sound dampening. I put 1 LED cannon under my x-fi sound card at the bottom of the case and the other at the bottom of the 5 1/4 cage under the CD drives. I put one cathode on the top of the dvd drive and the other I stuck to hidden side of the Power supply. Here's a diag...the red circles are LED cannons and the orange circles are 6-inch cathodes.
and its really not that bright at all, I took the pics with the lights pitch black in the room show the lights would stand out. Also if I feel like its too bright but want to keep the computer on, I still have the solid side panel that I can just put on that covers most of the light.
dolphumous said:I used your 'hints' to help out my P160
http://www.hardforum.com/showpost.php?p=1029210967&postcount=4012
Thank you![]()
I hide it along the rail that you see with the green zip ties.Boyo said:It looks nice. How are you hiding your case fan wiring???
check out the rest of the pics in the other thread.HaMMerHeD said:Now I'm inspired to rewire my own P160.
Damn you all...making me do stuff...
