P160 Problems
Mokster
Hi,
Just recently got the P160 and I'm having a few problems...problems that others on this forum has had here:
here
here
basically the audio on the front panel is reversed and the temperature LED is not displayed...
is this normal? do i have to do something to turn on the temperature LED? any way to reverse the audio on the front panel? it is plugged into using azalia (or something like that)...
figured it out, forgot to plug the power in for the LEDs and I can't use that azalia plug for P160, have to go with the legacy plugs, and even then you have to switch the LEFT and RIGHT...
Yeah, you gotta plug it in. Bad thing about me, I fried mine so i gotta pay $28 shipped for a new one. It sucks.
Anyways, I decided against using a lot of the panel ports. So no audio, no usb, I pretty much only keep it for the temp display (which is fairly inaccurate) and the PW & IDE LEDs. And to turn it on :p
Anyways, if you thinking about wiring it up nicely take a look at my thread. A ton of pics pretty much showing what I did.
http://www.hardforum.com/showthread.php?t=1058187
