Overlocking Issue - A643000 - Crashes when any games/3dmark/etc are initially opened
iibbmm
I am having a hard time finding any reference to this being a typical issue. Hopefully I'm not being a complete idiot, but I'll be forthcoming of the fact that I'm not really an 'overclocker.' In fact, the thought of me posting on the Hardforums makes me giggle like a schoolgirl.. but I need help so it's time to swallow my pride since you guys actually know what the hell you are doing.
Specs :
A64 Winchester 3000+
Abit Av8
4x512 Geil PC3200 GE1GB3200BDC 2.5 8-4-4
BFG 6800OC (no oc or unlock)
A 200gb IDE WD HD, and a 60GB IDE WD HD
So basically I can overclock up to 2.4 or so without any issues running normal applications, but if I open any games I have installed, or run 3dmark, I get a black screen. With 3dmark the program will open, but once I tell it to start the test it fades to black and stays there, which is good for a Metalica song, but sucks for a computer. if I open, say, CS source from Steam, it will go black and stay there.. same thing.
Any ideas on what causes this? Happens if I do ANY kind of OC (even going from 200fsb to 205). My temps are fine.
When you OC to 2.4, do you test it for stability with Prime95.
However this sounds like your PSU cant handle the load. When you start gaming/3dmark, your GPU starts pulling a good deal more power. If the PSU cant handle it, it'll cause a crash.
I am using a 400W 'Ultra' PS. It's the one with the modular cables. Anyways, it's crashing before any real load is being generated. Say I open Half Life 2. it goes directly to black instead of the Valve logo coming up. I doubt that the menu system is generating a huge power load.
Does everything work fine at stock settings? List your mobo, sata or pata drives, etc. Have you tried 1 stick of ram? Bump vcore up 1 notch?
Find your LDT multiplier and drop that to 3x. If you're not adding voltage to your processor, you're probably going to have to in order to sustain 2.4GHz on the Winny stable. Basically, as you overclock your processor, it uses more power (voltage) and generates more heat as you raise the clockspeed. Obviously, there will be more voltage on every stock CPU than the core "needs" and the need of voltage per clockspeed is different for each core...so there's no set standard for what works until you figure it out. When it's not getting enough voltage, it's starts miscalcuating...your CPU is like an expensive calculator (more or less). If your overclocking too high, 2+2 will = 5. Not good. Must = 4. ;) Download Prime95 and run the SmallFFT torture test on whatever overclock you're setting...if it errors out, it's not stable. I consider 48 hours 100% stable (as do most people). For reference, my Venice is 48 hours stable.
Also, read Eclipse's sticky in the AMD processor section for a good view on how to overclock. PM myself or him with any questions, we'll be glad to help out. :p Best of luck.
Everything works fine if I bump it down to factory spec.
I've tried one stick of ram, I've tried two, I've tried three.
I have tried adding voltage and leaving it factory, same results.
It just seems to me like it has to be related to the video card, as it only does this with games and 3dmark. I can pop it up to 2.4ghz and use my computer without an issue as long as I dont open a game or 3dmark. Every other kind of application works flawlessly.
