-=ABUSIVE-69=-
- Mar 21, 2006
Asian Dub Foundation said:no pcie 16x?!?!?! fubar!
It looks great already; there are other interesting applications for computers aside from games.Doorbasher said:If we ever *do* see a game that can handle 16 threads, however, this thing starts looking mighty nice.
I'm pretty sure he was talking about PCIe x16 slots for SLi. They make RAID controllers in x4 now though, I think.Stang Man said:PCI-X is the way to go in a server board
DaCoOlNeSs said:holy shit, that QK8S needs a 6 Pin and an 8 Pin plug, PLUS the 24 pin, wonder if its running a quad CPU server![]()
edit: is this Abusive not the brightest crayon in the box? all the posts I've seen from him are terrible.
DaCoOlNeSs said:jesus christ, thats insane.
Well, no arguments except for the numbers. 4GB/s is the signaling rate*channels, true, but there's 8/10b coding, so you're really only sending 3.2GB/s of data.defakto said:A 16x pci-e slots offers 4GB(8GB full duplex) bandwidth which would be fantastic on a high end scsi controller or gigabit nic.
unhappy_mage said:Well, no arguments except for the numbers. 4GB/s is the signaling rate*channels, true, but there's 8/10b coding, so you're really only sending 3.2GB/s of data.
And why would you need 2 gbit*16=32gbit for gigabit network, or even 10gig network? x4 would be plenty for a server-type 4-port giganic (or 8 if you could physically fit that many) and almost enough for a 10gig link. Other than physically holding the card up, there's no need for a bigger slot than that for network.
Well, if you're using "thousands of MiB" to mean GB... I've given up on expecting a definition of GB that works everywhere. Sure, I know, GiB versus GB, but nobody actually believes you're doing that. GB means billions, not 2<<30s.AreEss said:250MB per; but your signalling math is actually off there, mage. It's 2.96GB/s-3.33GB/s; we're not hard drive manufacturers. 250 * 16 = 4000MB = 3.906GB.![]()
Just hypothetically speaking here... Pci express is a switched architecture, right? So each lane of that x16 slot is identical to each other. Why not have a card in x16 size with 8 seperate 2-lane devices, each of which talks to 2 lanes and produces gigE on the other end? That would be a really cool thing to see... you could do it with VGA, too, for large multi-monitor displays, if you had a small enough VGA chip.AreEss said:You can physically fit 8 with a mezzanine easily, but no, your combined latency makes things ugly. 16x is overkill for a quad-port, sure. However, 4 lanes gets you 1GB minus overhead call it 750MB times 8 gives you about 6Gbit, except you're also latency stacking. Bus + Cable + Distant End, which tends to cut in very deeply. It's nowhere near enough for a 10Gbit link in the end, unless you're talking FC-AL. (But HTX is out there now for InfiniBand, so why would you bother?)
Pushing in what sense? Using to capacity? Recommending to manufacturers? Selling on street corners?AreEss said:So I probably shouldn't mention that I'm pushing triple-16x physical in 16x/4x/16x. With five PCI-X 133's backing it up.![]()
ValeX said:Can you run that board with less than 4 processors? That would be a kick ass board if it had PCI-E 16x for SLI or even Xfire.....damn, huge power potential there.
-=ABUSIVE-69=- said:
