Overheating
Eze1
Notice the tempatures. I have A heatsink fan, a HUGE fan on the back, a fan on the side and a fan below that. So why is my temps so high? I am using the program called Speedfan.
http://img238.imageshack.us/my.php?...untitled3pe.jpg
Speedfan
This is one of my fans
http://www.mcmcomputers.co.uk/images/EXHAUSTFAN.jpg
This is my other fan
http://www.ehomeupgrade.com/forums/...ttachmentid=990
this is my other 1 <---this is a pretty big fan
http://www.frozencpu.com/images/pro...s/fan-141_2.jpg
Then a regular fan ontop of my heatsink.
All of them work
Got suggustions?
Okay, those links work...
YARDofSTUF said:
What heatsink do you have?
and are those load temperatures? or idle?
Looks like your chipset is burning up, how's your case airflow?
Which Prescott..?
I don't think Gigabytes report higher-than-usual temps...anyone else?
Is it dusty?
Whether its dusty of not it still happens. I will tell you any information you need but you'll have to tell me exactly what do you
Dust in the heatsink will inhibit heat dissipation.
..and tell you what? :confused:
I don't think there is dust. I could get a can of that airspray stuff and see what I can do. Tell me what? if you need to know the model of whatever I have tell me how to get it and I will tell you what it is
Im thinking half the sensors on that are bad since your first HD is 17*C? thats kinda cold for a hard drive in a case with temps in the 60s! I would check in your bios to be sure what the cpu/case is, but dont take those verbatim.
Not really sure what to say, what do you need answered again, sorry.
Oh yea I have a harddrive fan aswell I totally forgot all about that.
I really don't know what to check in my BIOS
Itl say somthing about PC health status. Just look at the temps. They should be labeled at least CPU and system and will tell you how hot they are. Dont really want to go above 50-60c for the cpu as an upper limit and 65 as the oh shit wtf is wrong with my heatsink/fan kind of temp.
The BIOS and software utilities usually share the same temp diode, no?
www.cpuid.com works well
..and nevermind that's an idle temp...which is bad bad (if true).
Holy crap look at that 5v rail... :eek:
Maybe the BIOS will report something...a bit closer.
Are you using the stock heatsink/fan that came with the processor? Have you messed with it before?
yeap its a stock fan and I got my processor back in Jan but I've had this problem starting from NOV 2005 which is one of the reasons that lead me to but all of these parts to see if it will fix it.
