Have a system here that is reporting temps of above 88C whilst the case temp is being read as 22C. Now, all 3 fans are running. There are two 120mm fans right next to the HSF which are out take fans as well as the fan on the heatsink.
The case feels very cold inside, as well as the air from the out take fans. Also, when I turned the computer off, I opened the case right away and felt inside. The heatsink was not hot at all and the same goes for anything else.
I had to turn off the function to shutdown the computer so I could run it, I did this because I find it hard to believe the CPU is at that temp. I'm sure the HSF is mounted correctly.
The motherboard is an MSI PM8M3-V, I tried to download the BIOS but the MSI website doesn't come up with anything.
So right now, it's all running linux but in modulated clock mode..
