Overheat Prob
Razputin
I'm looking for any suggestions to my problem.
I have an AMD 1800+ in K75SA MB not overclocked and it's been working fine for past few years. About 1.5 years ago I replaced the coolermasterer HSF with a copper version using AS5. Last night I was getting total lockups/bluescreen while heavy gaming. Checked temps and found case to be 27C and CPU 65C. I know onboard diodes are not reliable but the HSF was very hot to the touch. That indicates to me that I still have proper heat transfer from the core to the sink. I opened the side of the case and pointed a large box fan inside and got the CPU down to 53C idle where it seemed to remain even after heavy loads. Is it worth looking at getting a new HSF or case(current one really bites). Why would this start happening now all of a sudden? I'll never make it through the summer like this in SoCAL.
nuf said
The only things that come to mind are:
Pull the HSF off the board and CPU and clean it with air and a brush. Its probably compounded with dirt dust and muck.
Ok thanks for the things to try.
I'll give it a nice cleanup and eventually replace the case.
Hopefully I can get it back to the 40C degrees I'm used to.
