Overdrive on HD3850 AGP does nothing
Alfa
Hi all,
A couple of weeks ago I bought myself a Club3d HD3850 AGP card and so far I have been pretty happy with it (used to own a 6800GT, which was also a nice little card)
The only thing that I am not able to do is to overclock the card using the CCC. Whenever I set higher clock speeds and hit the Test button, the clock speeds immediately go back to stock speeds (GPU 699 and Memory 829) and does not give me the option to Accept or Restore the new clocks.
Autotune does not work. It seems to just constantly test the stock speeds
Tried to create a profile and manually change the xml file in the ACE folder to higher speeds but when I activate the profile, the slider jumps to the higher clocks a millisecond and immediately back to the clock speeds again.
Also, I can overclock using Rivatuner but this keeps the speeds constantly in 3D speeds, which I don't like.
Not sure if anyone experienced this as well and maybe has a solution to this problem.
I am running the 8.4 agp hotfix driver btw
Ciao
