Overcool Your Xbox 360
HardOCP News
[H] News
Sure you can liquid cool your console like we did but thanks to the new Lian-Li cases for the Xbox 360, you can also use massive heatpipe heatsinks like this guy did. You’ll need a translator if you plan on doing more than looking at the pretty pictures.
Or you can click on the British flag (next to 'Choose language: ' text) on the top of the page, and get a British version of English :)
Pretty sweet mod, haven't looked yet if they did manage to replace the internal drive with the HD-DVD drive.
Well, that would certainly take care of any heat-related RROD issues. Nifty.
Ill do the translation ;) i can provide atleast 90 % accuracy in the translation, im not sweedish though, im waiting for the server 2k8 download from microsoft, and then the install on the esx server anyways so why not =)
Good mod if overclocking yer XBox.
He is overclocking it right...
Just messing, superb mod :D
arg gotta do dualpost, get 120 gb hdd, copy the dvd to the HDD, you can do it in the new patch, but you gotta have the cd in to be able to play to counter piracy, but it doesnt make much noise :p
Now if only there was a way to quiet the DVD drive :(
Flash it with hacked firmware that runs at 8x or 5x. 8x is barely audible and 5x is completely silent.
Back on topic... With those two huge ass heatsinks, even if they cool decently, it will 3rlod soon enough due to the heavy heatsinks warping the board. And did I miss the temperatures or are they just not there?
gotta love google translator:
Warning: As there are currently only possible to draw Noctua coolers with 2st screws without making new washers attached, so put me first of all the pasta to check the evenness of pressure, the conclusion is wrong here, you can easily destroy any of the integrated circuit after this " pressure test, "I took the course, eliminate redundant pasta. And then came the screws a little at a time with your fingers until the cooler was an entirely plain, then I went on with the screwdriver gently.
:p
Jag har haft Xbox360 från dagen den släpptes, och under alla dessa år har jag blivit lika glad varje gång jag har stängt av den!
TRANSLATION:
I have had the Xbox360 since the day it was released, and after all theese years I've gotten just as happy every time i shut it of.
Now not because of the games, but the sound of it.
Have then bought the new elite, and having the same issue with the noise.
There are thousands of threads in the hunt of "Jasper" in the hopes of a better and more quiet one.
Just as many about "RRoD" and hundreds on solutions on this issue.
And since I saw lian li show their PC-XB01 case have I dreamt of taking my claws?( or do you guys also say put my teeth in it) and see what you can do to make it quiet!
Lian li have done a good description on how to build it.
http://www.lian-li.com/v2/tw/product/upload/manual/XB-01-E.pdf
I followed it step by step, You just have to think about to have all those torx bits or screwdrivers at home before you start.
And i wanted to do more than some "simple fixes" i like noctua and their coolers so the target was to see if it was achivable.
Here comes pictures in the attemt to get 2 pieces of noctua coolers by the model NHU9DO, this is for AMD Opteron cpu's
Looking akward or what ? how else should you be able to fit them?
(asuming this is will be correct) will the cooler have equal contact over both the gpu and the cpu.
Really akward.. The fins goes into eachother.. what you have to think of with theese coolers are that they isn't symetrical, you can see it easy on this picture:
Its important to turn them apart from eachother, then they will go precisly in!
Now does it look good, time to clean cpu / gpu and check that the coolers will fit over the die surfaces.
I just used some thermal compound on the gpu, screwed it on and took it off and took this picture to control that it was even!
Warning: today can you only screw it in with 2 screws (not the bracket) did i first put on all this thermal compound to controll the contact, to make sure its even. if you screw it too hard in you can ruin some of the circuits, after this "pressure test" did i take off some of the overflooded thermal compound. And later did i screw them inn with my fingers till the cooler was was abit tight, then to screw inn veery gently with a screwdriver.
( så please no mails about how thin or think layer you should have, thin and medium is often the best :) )
Then was was it to screw up again.
Here do you see the chips and the nuts that you need to buy ( Lian li and noctua do not supply theese)
Then was it to test it some, Some "Zuma" to test load the gpu.
After some hours with testing diffrent games, was i satisfied to test it in the case.
Mounting the dvd, harddrive and the other small details.
Now have i run it through some games for some hours without any issues, it seems like the xbox doesnt like to change the fan speeds, even at high loads, which I take as interpret as low temperatures on the cpu and gpu
I have some specs from Noctua
Model Noctua NF-B9
Rotational Speed (+/- 10%) 1600 RPM
Rotational Speed with L.N.A. (+/- 10%) 1300 RPM
Rotational Speed with U.L.N.A. (+/- 10%) 1000 RPM
Airflow 64,3 m3/h
Airflow with L.N.A. 52,6 m3/h
Airflow with U.L.N.A. 41,1 m3/h
Acoustical Noise 17,6 dB(A)
Acoustical Noise with L.N.A. 13,1 dB(A)
Acoustical Noise with U.L.N.A. 7,9* dB(A)
I do not have any RPM guage, but should appreciate that the fans are spinning with the 1100-1200 RPM, and with 2 fans we are probaly talking about noise levels around 13-15DB by my guess.
Or to explain the noise level in a diffrent way, I cannot hear the diffrence between the xbox and the laptop when I'm in the room with both.
*no hotlinking please -Steve
All of you are fucking retarded, you can hit the English icon in the top and it's written in perfect english...
Jesus...
.... Now where's the overclock.
LMAO
Big ROFLWUTUFAIL at all those trying to translate the article when there's already an english translation there :D
For the 2000th time, we say "bring your own translator" because the translation tools built in do NOT work on everyone's PC (mobile, Opera, Ff, certain versions of IE) . :rolleyes: We have a broad range of readers and we like to think they can use the translator of their choice if they want to. Some people are NOT translating it to English or to another language, we try to think of everyone not just English speaking IE users.
As for calling everyone 'fucking retarded" you might want to learn some manners if you want to continue posting here. I know you are a n00b and all but it is still uncalled for.
No offense Steve but.. it's a fucking different page (http://www.silentxbox.com/xbox_eng.php), not a translator nor a translation tool.
People really need to blind to miss the big "Choose language:" text at the top with the Swedish and British flags.
My God. I need to learn about the pasta.
So how do our Spanish readers read it again? How do our Japanese readers read it? How do our German readers read it? How do our mobile readers read it when the buttons don't even display?
Jeez man, think beyond "English only" please and realize we have readers from every continent on this planet.
....SO, we say it every time a translation could be needed.
Well considering the entire forum is in english, unless you plan to translate every thread through a translator, which seems to be a huge waste of time, IMO, you can probably read english to some degree.
My Xbox just went out of warranty...I was thinking about doing something in a new case, but I would probably just weld an aluminum case together myself instead of paying LianLI part of what a new xbox would cost....
I was looking at building my own case for my 360. Well, more like modding a regular PC case. I have 2 other RROD 360s laying around. I never got around to heatgun fix them. I'd have to make some ghetto rubber standies to help fix the warping mobo issue. I also have Koolance waterblocks laying around, so I'd go with them instead of air.
There's also mods out there to use a PC PSU with your 360. That's why I'm shying away from the Lian Li case. I personally hate that stupid external brick (as do many others). This would also help with the watercooling setup. I'm leaning towards a Lian Li PC-V800B. I like the way the PSU gets mounted inside the case.
you can do pretty much anything to an xbox but who really has the time?
i have better ways to spend 100s of hours.
You mean like post on this site 2800 times?
It doesn't matter what you do really. Everyone has hobbies and I'm sure ppl would say yours are a waste of time too.
thats what i'm saying, its a cool project but i dont have 100 hours to learn, research, and do something like this.
Well it looks cool but then again the price for custom cooling just makes you think about just getting a gaming pc.
