Overcloking 9700pro, will it run smoother?
Betauser
ok, im having a hard time of playing FFXI if i set the shadow, and weather on especially when im at huge crowd... so my question is, will my 9700pro improve this if i oclock it more? maybe to 9800pro speed? and if these 2 features is off, it runs a little bit better, but ofcourse i want to be able to use them as much as possilbe. btw, all settings are max.. running at 1280x1024. any suggestion would be great..
Overclocking does increase performance but not in a large amount. I doubt the increase in performance will make that game run smooth with those settings turned on. You may want to turn down your resolution instead.
