- Feb 23, 2004
Use the latest version of afterburner beta. I'm using 2.1.0 beta 7, go into settings and enable voltage control, set your voltage to 1300mv. then open up CCC and under performance, AMD Overdrive, Power Control Setting - set to +20%.
Apply all settings.
Now reopen Afterburner and start tweaking your core and ram. On my XFX I was able to max my cards in crossfire to 938mhz core 1430mem on both cards @ 55% fan speed cards hit 62c under furmark multi gpu load.
I'm more limited by my 700w psu than my cards I believe. Once I get a newer psu I believe these guys will hit 1000/1450 much like my 6850's last week.
send me a pm if you need anything specific.
And yes smartdoctor requires an ASUS bios on your card. Brand of the card doesnt matter, my gigabyte 6850's were flashed as asus's for the increased core and mem speeds.
You should not need 1.3 for 938core. It should do 938 core on stock volts, or at least 1.175. 1.3 volts should get you over 1000 core.
